spring rate question
bribot
Car: 01' jetta 1.8T, 83' GTI, 90' s13 hatch
ive been searching around for a kg/mm to lbs/inch conversion for a 9/7 spring rate but couldnt really find anything about it... does anyone know what 9/7 springs would be in lbs?
BadMojo
Car: 2007 Mazdaspeed 3
bribot wrote:ive been searching around for a kg/mm to lbs/inch conversion for a 9/7 spring rate but couldnt really find anything about it... does anyone know what 9/7 springs would be in lbs?
To convert from kg/mm to lbs/in divide by 0.0179, and multiply to go from lbs/in to kg/mm.
So, 9/7 would be about 500lbs/in, 390lbs/in.
nismofly
Car: 89 Nissan 240SX Hatch
not sure what youre dividing, but to go from kg/mm to lbs/inch you multiply by 56
so its 504/392 to be exact
bribot
cool thanks alot guys
BadMojo
9 divided by .0179 will convert it to metric. either way, it gets near the same #. I think the .0179 method is a bit more accurate, but it's not enough of a difference to be important in most cases. kind of moot. I guess multiplying by 56 is easier to remove.
hannibal
Car: Red Line to Glenmont
Its the same thing1/56 = 0.01785
BTW the exact conversion factor is 55.88. So using 0.0179 is more accurate than using 56.
9/7 is 503/391 (rounded to nearest whole number)
