SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Wed Jul 02, 2003 9:25 pm
Hmm, interesting question. Generally, there is no ill effect of a strictly stiff spring(not addressing length of spring, or ultra-short springs causing bottoming out of shock) on a shock absorber that is performing like new. One could argue that the action of a stiffer and shorter spring is much faster and causes a sharper jolt to the shock as it dampens the action of the spring..... causing the fluid within the shock housing to heat faster, or overheat, or causing the piston to score the shock internals, thereby causing early shock absorber failure. You might be hard-pressed to find data to support that idea.
The main thing we need to remember is to mate a proper length spring to a shock with a range of motion(length of shock travel) that works with your spring. Nowdays, that isn't too hard, as many companies offer springs/shocks or one-piece coilovers which take the guesswork out of it.
If you upgrade your springs, you most definitely should upgrade your shocks/struts. The OEM struts are probably beat down as it is, and will not be able to dampen the sharp bouncing of a shorter, much stiffer spring.
So, chmercer, imagine that when you install stiffer springs, you are now asking your OEM strut to work harder to slow down the action of the spring, and also forcing it to do that work in less time, because of the shortened distance from stationary ride height of OEM springs to compressed height of shorter springs. There is more(and harder) work to do, in less time to do it. This, combined with already half-dead OEM units, are some of the reasons OEM shocks tend to fail.
Still, the main problem I see is the 2-2.5" or lower drop that ruins all ride characteristics, causes the car to ride on the bumpstops...effectively removing the shock absorber from the suspension equation, and blows out nearly every strut ever designed.
A couple of suspension basics links:billzilla's susp.
Vincent C's suspension basics
More of Vincent C's suspension
