Spring rate conversion kg/mm to lbs
LiteraryCannon
delete
Modified by LiteraryCannon at 11:51 PM 6/16/2007
nismofly
Car: 89 Nissan 240SX Hatch
ive always used 1 kg/mm = 56 lbs
5 x 56 = 280lbs, 7 = 392 lbs, so youd probably get a 400, and 8 = 446, so basically a 450
if youre getting springs with rates that high id recommend getting koni yellows, so you can get them valved properly for the springs
LiteraryCannon
delete
