Spring question.
Kevlar
Car: Fishing, Hunting, Camping, and Hiking
Hey guys,
I have a 91 S13 that had shocks and struts replaced all around (Tokico HP's). My driver side front is lower than the other side...The springs are Eibach sportline's which are about 8 years old now...My question is why is one side lower than the other? The shocks are brand new, however, the springs are kinda old...I called Eibach the other day and they say that even if the springs are old they should never sag unless they are faulty in the beginning (which they weren't). My mechanic says that the spring is sagging but he isn't much of a performance mechanic and might not know about what eibach has told me...I don't know if they were installed wrong or the left and right sides were switched...Anybody have any experience with this? Thanks in advance for anybody who has any input on this...
Regards,
Kevin
BooFa
weelll.. actually... if the springs are that old - and they've been on the car for that long.. and travelled. .let's say... 120,000 miles.. (15,000 * 8).. the spring might be worn?.. cause that's what happened to my friend's springs after like.. 6 years.. or something like that.. and especially since it's the drivers side.. maybe the previous owner was a.. bigger guy.. ??.. lol -... i'm prollie wrong.. but it's possible!?...
p00t
spring could have been installed wrong or shock is weak/blown.
I have prokits, and with one side installed upsidedown, it was definately lower than the other. Why was it upside down? well... oops?
You will visibly know if its installed upside down, and if the shock is bad that corner of the car will have more of a tendancy to bounce
Ceptos
Car: 95 240sx
i dont think the shock would make the car sag...it would definitly be noticable while driving, but i dont think it would have an affect on height, that would be the spring or some other suspension compenent, but, unless something feels really wrong on that end (either over bumps, or through a turn), i would say the spring. is this something that occured right after the install of new shocks?
CiPHeR_Tx
possibly damaged lower suspension components...ball joints...control arms...stuff like that. i have eibachs installed on mine...also new shocks all around. heh...i also accidentally installed my front passenger spring upside down...front end has been level so far
Kevlar
Thanks guys...I did call Eibach and they say that even after 5 years that their spring will not sag...Now that I think about it, it could have been installed incorrectly...But my mechanic told me that I do need new ball joints and all but I don't think that it would affect the ride height...The shocks are brand new...Hopefully i didn't get a defective one...How can I tell if the spring is upside down? Thanks again everyone for all the replies...I really do appreciate it!!!
Kevin
p00t
for any progressive rate spring the coils wind closer together near the top. what ever end is supposed to be the top will have the last 2-3 rows of coils much more closer together than the bottom.
________ top________________
________
________
________
________ bottom
get the idea?
CiPHeR_Tx
don't worry about the shocks....they don't affect ride height at all...thats the spring's job
Kevlar
Thanks P00T and Cipher_TX!!! That little pic made me understand! I will go outside and jack the car up and check it out...Will let you guys know...
CiPHeR_Tx
no problem kevlar...keep us posted
