Then for rallying he needs to weigh in his navi, HAHA .Exar-Kun wrote:What are you shooting for, car wise? Mostly daily driver, etc?
I'd shoot for 51%f 49% rear, as this will give you just a tad bit of understeer naturally, but should aid corner exit speed nicely.
Also, do you plan on getting it done with you in the car, or without?
-Chet
Your weights are worthless after you install new suspension.Red coupe wrote:ok while we are on the subject...I to will soon have KTS and I have access to scales for corner weighting what should I be going for as far as each corners weight? I know as even as possible on each side, so should I set the heavyer at 0 preload then try and match the other? also what should I aim for front to rear? As is now I look like this... LF:759 RF:769 LR:624 RR:608
