C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Feb 28, 2006 11:05 pm
Teh only time preload would actually have an effect on stiffness at static ride height would be if you precompressed the spring so much that it's compressed length is shorter than the length of the spring would normally be under just the weight of the car.
Keep in mind that a car's weight will remain constant(assuming same fluid levels). A spring compresses under load. The more load you put on it, the more it compresses. Lets just assume we have a car with 500 lbs at each corner. With a 100 lb/inch spring, each spring would compress 5 inches. Now lets just say you precompress the spring in the strut assemblies by 2 inches. The spring will have a 'preload' of 2 inches and will be puching on the spring perches with 200 hundred pounds of force. As you start putting load onto the spring, the spring will remain at teh preload height until they see more than 200 pounds. Then it will compress another 3 inches as you put the remainder of the weight on the springs. Ultimately, the spring will still have a total compressed height of 5 inches. this means that the actual ride characteristics will not change except that you know have 2 inches less rebound travel from normal ride height.
Now lets pretend you preload the spring 7 inches. This means the springs will be providing 700 pounds of resistance to teh spring perches. When you lower the 500 lbs of weight onto the springs, the resistance will not be exceeded so the suspension will not compress at all from that point. Essentially, unless you hit a bump or corner with a load that exceeds 200 lbs for a given spring, that spring will not compress. And since it's not compressing under static weight, the suspension is effetively riding at full extention. The tires will be unable to maintain contact when you get small dips in the road. This is not a good thing.
Now I will say that I'v enever actually seen the term preload used in suspension spak before. None of my references mention it. I am making assumptions as to what you are descriing as I can not think of what else it can possible be. But if we are describing the same thing, then you really only need enough preload to keep the spring from moving within or falling out of the spring perches under full extension. You should be much more concerned with the vehicle's cross-weight.
