everything is still on for today for anyone that is coming from a longer distance. There is also going to be a meet after the meet at a local shop with a dyno.
http://artinmotion.myunite.net/unt?id=390
After the spring meetdynotuned will be having a dyno night for everyone in the area!! we are minutes away from were the honda-tech meet will be .. i hope to see a good out come.!!!
only RWD /FWD
all HONDA'S ......................2 pulls 40$$>>>maybe 3all NON honda's..................2 pulls 50$$
Where: 5506 Hwy CV Madison, WI 53704When: Sat the 25th after the honda-tech meet... around 5:30pm OR EARIER .. WEATHER DEPENDING!!
photo's will be taken and set to the individual's (if wanted)
directions :: FROM MEET TO D.T.P1: Start out going NORTH on CANTERBURY RD toward NEWBURY CIR. 0.2 mi Map
2: Turn RIGHT onto RAYMOND RD. 2.1 mi Map Avoid
3: Turn LEFT onto US-151 N/US-18 E/VERONA RD. 0.5 mi Map Avoid
4: Merge onto US-12 E/US-18 E. 4.5 mi Map Avoid
5: Merge onto JOHN NOLEN DR via EXIT 263. 2.9 mi Map Avoid
6: Turn SLIGHT LEFT onto US-151/S BLAIR ST. 0.2 mi Map Avoid
7: Turn RIGHT onto E WASHINGTON AVE/US-151 N. 1.4 mi Map Avoid
8: Turn LEFT onto N 1ST ST/WI-113. 0.2 mi Map Avoid
9: Turn RIGHT onto E JOHNSON ST/WI-113 N. Continue to follow WI-113 N. 2.4 mi Map Avoid
10: Stay STRAIGHT to go onto PACKERS AVE/CR-CV N. Continue to follow CR-CV N. 1.6 mi Map Avoid
11: End at 5506 County Road Cv Madison, WI 53704-6164 Map
Estimated 15.96 miles
