ScrapnSidwayz wrote:hey man what is spring drooping? i have heard of a lot of stuff but never that.
haha i think we had a small convo about the spring preload right?
well drooping a spring really only applies to the rear because the fronts are designed differently
when the front spring is fully up with no preload and the purch is all hte way up to the bottom of the spring (i.e. lowering it) to lower it further you need to compress the spring (preload) and then move the purch up to meet the bottom of the spring again
with the rear, preloading it makes the car rise higher haha, so when you got the bottom purch maxed out, there is no more adjustability but in the spring, so you lower the spring down so that it no longer touches the top but there is space now
this means the strut compresses before the spring does, so it lowers the car
the drawback is like i was telling you, when the coilover has no force on it, there is that potential that when force is added to it the spring will not seat correctly which is why its usually proper to seat the spring correctly wtih a bit of preload
the question basically is how much will my performance stuffer when i droop it because it for sure wont improve it and im trying to see if the minor aesthetic gains would be worth it hahaha
