EniGmA1987 »
https://forums.nicoclub.com/enigma1987-u132649.html
Mon Aug 18, 2014 10:57 am
Spring cutting is definitely a bad thing. If you need to lower the car, get springs designed to ride lower. Using cut springs will just drop you without changing the spring rate, which means you be much more likely to bottom out the suspension. Using springs designed for going lower will give you a stiffer rate so that more force is needed to compress the springs, this will save you from bottoming out and breaking your suspension. Cutting the springs will also make them unable to cushion in a uniform manner against the parch, since the bottom support has been cut off. Cutting the springs on the car is nuts too.
