And this is how she sits now after 3 weekends of work and more money than planned spent.
The Parts List
BC Racing BR Type Coilovers 8K/6K
ISIS Suspension Arms
Energy Suspension Master Bushing Kit
ISIS Aluminum Subframe Bushings
Energy Suspension Diff Bushings
Z32 Rear Calipers/ E-Brake
D/S Rotors
Agency Power Rear Z32 Conversion Brake Lines
Outer Tie Rods
Powered by Max Skid Plate
The Story
My plan was to install all of this during the first part of spring break but it didn't happen. I had ordered all of the parts and had them waiting for me when spring break hit. I started with removing everything off of the car and getting it ready for all of the new goodies. This is how it sat when it was finished and how it sat for two more weekends.
There were many reasons behind this but the main one is that I was sent the wrong bushings set. The ones that I was sent when I order everything was the ones for an S13 and not an S14. I called the company that I ordered them from and they realized it was their fault and apologized but would not do anything about it. I was able to return the bushings but they said that there was no way for me to get the new bushings in time for me to finish in the time I gave myself. They gave me some story about how I wouldn't be able to get the new ones for about 2 weeks or so. Which ticked me off and I just went and got new ones from amazon.
After I finally got all of the parts that I needed I finished the project. I had to get the first couple of threads on my axles shaved smooth so I could get the nut back on them. I also had to do some shaving on one of the subframe bolts to remove some rust so I could get the subframe to fit back on the car.
I have learned a couple of things in doing this. Make sure to have enough time to do everything that you plan on doing and also make sure that the jack you have is a decent one. I did have a little $20 2 ton jack but one time when I was jacking the car up to bleed the brakes the car slipped off the jack and fell and hit me. Luckily I wasn't sitting under the car. So I went out and bought a low profile 3 ton professional jack that is about 4 times the size of the one I had.
The Pics
Coilovers
RUCA
Tension Rod
Traction Rods
Rear Assembled
Rear Brakes
Front Assembled
Speed Bump Anyone
