spray
flyboy367
Car: 95 maxima se 5spd
anyone running spray? might be a cheaper alt to a sc or turbo. less beatin on the motor as well. daily anyway. what size, brand are you running and mods to the car. also times would be sweet.
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
"might be" is the key word. wet is cheap, dry is expensive. which one do you want? also with wet don't go over a 70 (i believe) shot - you can get more out of a dry setup.
flyboy367
actually you have it backwards, wet is expensive costs more for the fuel solenoid, jet, line. its also safer since it add fuel to the mix you have a lower chance of going lean. i have been around the stuff just havent used it myself
danielekfuj
Car: miata, rocket ship
I would not recommend a dry setup to anyone, have you read the FAQ?
zerothread/231254
THT
Car: 96 Legacy L AWD 5spd wagon, 04 M45
flyboy367 wrote:actually you have it backwards, wet is expensive costs more for the fuel solenoid, jet, line. its also safer since it add fuel to the mix you have a lower chance of going lean. i have been around the stuff just havent used it myself
Plenty of orgers are juiced. You can go as high as a 75 shot without upgrading the fuel pump. I personally don't care for nitrous as the initial cash outlay is low compared to a turbo/supercharger however the cost does grow with each WOT run and eventually, it will be more expensive.
allensteiner
good catch...my bad anyways why spray? it's just a shot o power instead of a constant supply from a blower.
flyboy367
well im still considering buying the sc kit. i have never run spray before and judging on how my car runs after the clutch, flywheel, intake, throttlebody im machining, headers and exhaust. if its at a good street standpoint where im not overstressing the car pounding it to fire calls i may just stay like that and get the spray for the handful of times i can drug my wife and sneak to the track.
kzoosho
Car: Turboed 1997 Nissan Maxima SE
If you do get spray you will still need a afc of some sort and you would want a wideband o2 also to monitor a/f . You will find yourself spraying ore than you think.
flyboy367
well i wont be spraying on the street, and even with my badge id still need to register my car (if i keep the tank in it all the time) for hazmat stickers. nj is strict about n2o. i have squeegeed enough kids off the street with my rescue company. i dont streetrace anymore. i may drive fast but only when im on a call.
