gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sat Aug 04, 2007 5:01 am
Okay, I have had a moment of clarity.IF you have it to spend, I would suggest about 10mm of spacing front and optional in the rear. I have 17x9 + 27 out back on 245/40 tires. That hangs a hair to the outside of the fender, but does not rub anywhere, your +38 should be fine. Was I you, I would space the front out a little for the sake of aesthetics alone. You want to end up somewhere in the low +20's at least. Again, just a suggestion.As for tires, a 215/45 front and a 245/40 rear would be about perfect. The diameters would be about 24.5 inches. I can not suggest a 215/40 for the front as that is waaaay to small a tire. Hopefully you have coilovers because lowering springs will not cut it up front. That gap is HUGE to begin with. Again, just suggestions.
