jiggy180 wrote:OK i checked out the guys ebay store and noticed he has the same wheels but in 17. I emailed him asking if he could piece together a set of 17x8 for the front and 18x9.5 for the rear. Seeing as i suck at this wheel fitment stuff, do you think this would be better? I have a feeling ill need a spacer for the front though.
17x8+35 front will clear fine, as long as you don't run a really wide tire. However, you will have a 1.5" wheel stagger from front to rear, which I don't reccomend. Even a 20mm stagger in tire size is enough to cause noticeable understeer on a stock suspension setup.
