sportlline springs
jin3000
Car: my car, car mutimedia, custom speaker and custom interior design
is anyone out there using the eibach sportline spring kit and if so are you still using factory struts.hows the ride?hows the handling?is the camber correctoins kit difficult to install?i know i can count on you guys to give the best advice.oh also,what are the largest whells and tires i can use without rubbing?.thanks
Lepchitz1
Car: Cars, and LESBIANS!!!
I have the sportlines with stock shocks and they ride great. I have had them for about a year now and the struts are just now starting to go out. I installed a camber correction kit ion the front which was really easy. The back will require a little bit more work. You can get the kit from PDM racing. You can search for the link. As far as tire size, I have 235/40/17 and i still have a bout an inch of wheel gap which is perfect. Take a look at my car (the link is in my sig) and you will be able to see what it looks like. I dont scrub at all.
