Sport Max/XXR 006 9.5" & Sportlines
21nemesis
Car: 1993 240SX SE
I tried searching, and maybe wasn't using the right words, but couldn't find anything. I am currently running the Sport Max/XXR 006 18x9.5" wheels and 245/35/18 tires in the rear with the Eibach Pro Kit springs. I have a set of Sportlines that I am hesitant to install because I am not sure whether or not I will need to roll the fenders? Anyone have this combo? If so, did U HAVE to roll the fenders? Or was there enough spacing that the tires wouldn't rub?
Thanks in advance
poshatch
Car: p.o.s. 1990 240sx hatch
rolling fenders can be avoided up to a point by running more of a stretch and more camber and higher offset wheels and ride height
if you lower your car more your gonna need to camber it more or roll the fenders
im pretty sure that you will NEED to roll them
it isnt a bigdeal you can almost just do it with a hammer or a pole, yes i know that sounds harsh! just be careful
21nemesis
Car: 1993 240SX SE
I would like to avoid that, since the car did get a new paint job not too long ago. And I'm already running a 245 wide tire on a 9.5" rim, which the recommended narrowest tire that should be put on a 9.5" rim. Also, tires at these sizes are not cheap, so running negative camber, is out as well. But, thanks for your insight.
TheBlaiant
Car: Slow40sx
Don't be a wuss Camber is where it's at these days!
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
it sounds like you dont wanna do anything to make them fit then. so you should either man up, buy different wheels, or leave your car alone.
poshatch
240sx owners....we make our cars fit our wheels
nismobenzo
Car: 240sx
lets see some pics of these wheels! ive been waiting a month for these to come off backorder in 17x9 but you obviously have the magic of 5-lug
21nemesis
Car: 1993 240SX SE
nismobenzo wrote:lets see some pics of these wheels! ive been waiting a month for these to come off backorder in 17x9 but you obviously have the magic of 5-lug
Actually, mine are 4 lug.
Gabes13
Car: rb20det s13
You probably won't need a roll.I've had a similar combo before.17x9 +35 with a 235/45 tire.The offset is high enough, that even with decent camber,the wheel/tire didn't touch the fender when compressed(pre roll).
Basically, with the drop of the springsthe wheel would have so much -camber when compressed,rubbing won't be an issue.
If in doubt,jack the wheel up in the wheel well, and check yourself.
