sport brake master cylinder part number?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
G27
Car: 2010 Infiniti G37X
Might need different threads for these questions but I’m also trying to figure out if the sport brake master cylinder will fit my 2010 g37x brake booster. I’m finding a few different part number but each one says they fit all models.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO!
Topics split and moved to correct forum. You were correct in thinking those questions should be separate topics. Splitting them up will help others who my have the same question, and will make it easier for them to search for an answer.
As for parts numbers, I use https://www.infinitipartsdeal.com/ as a reference guide.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Rogue One wrote:
Sun Jun 06, 2021 4:11 am
IPD may not help you directly if there are different brake setups used in the same MY, but chances are if the masters are swappable then there will only be one booster part number for the entire MY. You may be able to use that to find out indirectly. Enter your car generically (by model and year) instead of VIN and IPD will show you all the possible parts used for that MY. If it only shows one p/n (or one series with supersessions) for boosters then it's likely any master from that MY will bolt up.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
