I agree with this thought, it seems that for turbos this large you'd need all the breather mods (tb's, piping, dual intake) you said you didn't want to do because those turbos need the intake tract to be larger, and would surely need larger upgraded smics in order to see the benefits that size turbo gives. The stock intake tract just isn't going to be enough for the increased airflow.Fearspect wrote:Without a dual intake and larger intake piping, they will perform worse than the 550s: spool EXTRA slow and never reach their potential even when spooled.
This is absolutely not true, I've got HKS 2530s ( GT28Rs/2560) and they spool just fine with the stock intake piping 14.5 (WG boost) at 3500rpm and no drop off on top end.Fearspect wrote:Without a dual intake and larger intake piping, they will perform worse than the 550s: spool EXTRA slow and never reach their potential even when spooled.
This is a bad idea and I guarantee you these will spool, slower than the GT28Rs and will fall off on the top end very badly.twinturbozxtacy wrote:you can send the stock turbos in for a big wheel conversion and rebuild and save some cash. i was quoted 1200 and change for rebuild and t28 conversion on my stockers.
It seemed the OP said he didn't want to do the extra breather mods beyond what he had- Godspeed smics and he said he'd get MSP manis, 5 bolt DP's and ...BB turbos.300ZXttZMAN wrote:I think the 550 would be perfect for the OP's setup. Quick spool and will love the breather mods. Really can't go wrong with them on a stock block. You could always change them out for a set of 700s on your next build.
