Sporaddic RPM problem? (SEARCHED)
GoTRicEo0
Car: Slowest crap the earth have ever seen.
When I'm on light throttle, my RPM will stabilize under certain RPMs and start to bog.
I noticed in 1st gear it stops at 4K, 2nd and 3rd stop at 3K, 4th and 5th stop at 2.5K. My SAFC II reads AFR at 20.x:1 sometimes even 30.x:1 during light throttle. Punching the gas does not help either.
This may also be off topic, but my temp gauge does not work either.
I played with the MAF and I noticed the connections were loose. I repaired the connection but it still does the same thing.
I have a feeling its a sensor issue or possibly a boost leak. I have no access to a voltmeter and my tools are very limited. I have yet to check for codes but I will when I get the chance.
Anybody have any sort of idea on what it might be?
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
bump little buddy!
GoTRicEo0
well, I tried to narrow down the problem and unplug one sensor at a time and drive. Nada.
Pulling codes atm.
-Jeff
GoTRicEo0
While Pulling for codes, I noticed one thing. My ECU doesn't have an LED. Then... I saw adrian's old post on how to use an AFC or something like that hahaha. Installed the Z32 maf and running better then ever.
All in all, problem was a bad maf :[-Jeff
