Bluefire »
https://forums.nicoclub.com/bluefire-u7784.html
Thu Oct 12, 2006 8:04 pm
Do the easiest things first. Check over your entire motor, make sure nothing looks out of place. Next check your ecu to see if your getting any codes. Hopefully you will flash a code and then you will know exactly what your problem is. Next should be timing, assuming your idle is stable. The last would be checking electronic components, ie coilpacks, injectors, maf, iacv, engine temp sensor.
By the way the more info you give us the better we can help you out. BE SPECIFIC
-Bluefire
