spooling sounds?
TTZ32
Car: TT 90 300ZX
ive had my z for about a year now and ive trying to figure out all the after market items on the engine because my turbos spool way too nice to for the engine to be stock abd my friend has a completly stock tt and they sound and feel nothing alike.
sometimes i feel i got bov's and i know i dont.
so i have a k&n intake and stillen exhaust.. is that the big difference maker?
could it be a chip?
what else can it be?
Pieceofsand
Car: 91 300zx Twin Turbo
recir valve or maybe after market turbo. you said there is no bov's and the sound is from the engine bay?
TTZ32
Car: TT 90 300ZX
Modified by TTZ32 at 4:35 PM 12/31/2009
TTZ32
Car: TT 90 300ZX
dude i just check it.. definitely not a recircular valve
robomatic12
Car: 1990 300ZX TT
So you have the stock recirculating valves that you can see through the opening in the front bumper. Or by taking off the nose cover and peering down. They are probably replaced by aftermarket blow off valves in the stock location. Did you check there?
If not it must have bigger turbos installed, what boost are you running right now?
Once I thought I had a really loud spooling sound, turned out to be an untightened hose clamp on the turbo piping.
TTZ32
Car: TT 90 300ZX
yea definitely stock.. ill check hoses tomorroww. thanks
alright2020
Car: 92 jeep wrangler with SBC
99 F250 with 7.3 on 25lbs
91 300ZX na>tt>na
03 G35 coupe
you would notice negative aspect of performance with a loose hose. you arent giving a very good despriction... what rpm do you start building boost? where are you at full boost? what is full boost? other supporting mods?
TTZ32
Car: TT 90 300ZX
its not a negative effect and the sounds start once i hit 0 boost and thats what im trying to figure out, what other mods are on this car that make it sound like this.
alright2020
91 300ZX na>tt>na
03 G35 coupe
so you hear the turbos spool once you start building boost.... sounds like a normal situation to me? i really dont understand what youre asking here.... do you jsut hear excess wind noise or soemthing? something like youre fan clutch locking up and your spinnign yoru fan at leik 5k rpms? you should be able to hear your turbos spool....
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
In other words: Yes, the exhaust could do this. lol.
Z32 TwinZ
Car: 1991 300zx TT
ive got stock turbos with a full 3" exhaust and i hear my turbos spool. i love the sound. nothing out of the ordinary. just check your dp's and make sure the bolts are tight, if you have a leak, you will hear the spool louder than with no leak. i had a leak, my top 2 bolts some how came out of the passenger dp. after replacing the bolts, the spool went back to normal.
TTZ32
Car: TT 90 300ZX
thanks, z32 twins and speedeast
you answered my question.i just didnt know if it was normal for my z to be doing that load of a sound once the boost kicks in and i let of the throttle
and no, no leak.
tmbone98
Car: 1996 Nissan 300zx Twin Turbo
I know once I got a pod air filter instead of the factory airbox it made a big difference. I can hear it sucking up a lot more air and when i let off throttle it sounds BOV-ish, especially before i put the nose piece back on. Maybe you're hearing this?
