OM3GA wrote:Wow you have about the EXACT setup i want to run, A few questions:
Who does the tapping into the oil pan for the oil line? Its just a return line isnt it?
Are you using anything other than the JWT ecu for tuning? I plan on doing a JWT tune too but i heard with all drop in tunes you have to fine tune with an AFC...?
I plan on running around 10 psi boost and getting JWT tune around the same size injectors as you, same turbo, same maf lol This is awesome all on stock internals. Email me please if you can or i guess just reply on here but you are in CA like me and i want to do KAT for sure i just need help, And searching does not help when i have no idea what to look for lol.THANKS!
[email protected]
you can get an oil bung welded onto the oil pan, it's just a matter of cutting a hole in the right place(try and get it pretty high on the side of the pan) and welding the bung in. I did a different DIY route where I have a steel pipe coming out of my pan and up next to my motor mount, but the weld-in bung is the most popular way and probably the easiest.
I'm running a straight JWT tune, nothing else. JWT chips have been known to be a little on the rich side which can be corrected via a SAFC but my AFR's according to the dyno sheet hovered around the 13 mark which is fine.
noobdrftr wrote:mmmmehh...ive seen better. I kid kid that was awesome...got anymore vids?
nah, that's about it...not much of a youtube star lol
24j0hn wrote:im goin enthalpy, 370cc, sr mani, t25, 38mm watse, z32 maf, wideband, and a minor rebuild... lookin for 230- 250 on 8-10 psi
sounds good but a 38mm wastegate is unnecessary for 8-10 psi. Just use the stock t25 wastegate with an HKS actuator. Even the z32 mafs would be overkill for 8-10 psi, you can use a sr mafs.
slyedog240sx wrote: Thats right at minimum.I am sure that helps with the boost though.As long as it's reliable and runs well then you can't ask for much more.When running full boost do you see any smoke?At work and can't watch vid yet.
yeah it's not great but the car virtually has no oil blow-by. Even the oil level stays in the operating range for quite a while. I will rebuild eventually, but running this much power on a stock POS ka is just a freebie IMHO
brizanden wrote:car is weak sauce
