nismo1003 »
https://forums.nicoclub.com/nismo1003-u8632.html
Fri Apr 02, 2004 10:18 pm
I sold my T3 (300ZX) and trade in with Bigger turbo( i know it is bigger but I don't know the actiual size is), when I had the old one , it used to kick in full boost at 2400RPM(8PSI) ,but now this turbo kick in at 3400-4000Rpm full boost (9.5psi ,for some ough reason it is slight off) anyways , I honestly don't know the trim nor the spec of this turbo, , it bolt on to my T3 flange , does it means it is a T3? I know the compressor is much bigger than the old one I had . I just want to know is it late to spool up at 4000rpm full boost? for those of you got the T3/T4 , how quick urs spool up at what 8-9 PSI? thanx this turbo donesn't have a little nozzle outlet for the wastegate singal line, so what I did was to hook it up behind the throttle body ( throttle body > BOV nipple >Wastegate) , my BOV sounds different then it used to be) is there something wrong? now full boost at 9.6-9.8psi when my wastegate spring set at 8 psi? is it because the BOV signal line shoudn't be with the Wastegate line together?
I was on the way back home , I passed by a rice out Eclipse he took off, so I drop to 4th gear from 5th , I was at 2600rpm, he was pulling me away , and when I hit 4000rpm , I start catching him and passed him one and a half car lenght then I heard he shift gear then the BOV blow off so i knew either it was a GST or GSX anyway,there was traffic ahead and we were already going 110mph so we went out own way, i was impressed of the KA power ....lol
