Projex240 »
https://forums.nicoclub.com/projex240-u4020.html
Sat Dec 06, 2003 11:09 am
You won be able to "change the characotristics of the turbos sppol up unless you go into the turbo and have it rebuild with different specs. Too much money and time. If thats the case..just get another turbo. Also, deisel turbo are very efficeit, the only reason deiseil engines spin to 4k rpms is because the exhuast gases those HUGE engines spit out at 4000 rpms is enough to spool a turbo this size. Plus, the gearing on alot of deisel truck is so close, that they use up 20 gears to deisel trucks, so 4000 is all they need to get moving and a good pace.The turbo would be just fine for what you need, besides lag is only against you if yyou want to start a race at 1500 rpms or so..and since most folks start out at 3500-4000 rpms in a run, then lag isnt even a factorYou cant get rid of lag...but you can reduce the lag "time" if it takes you 3 seconds to build boost when going from 1500 to 4000, then theres room to improve. Use a lightweight fly, pulleys, a good 3 inch DP, 3 inch exhuast, test pipe, and if you want to, use a 1 peice 11lb driveshaft from enjukuracing.com. instead if 3 seconds, itll be more like 1-1.5.Thats about as good as it gets, bud.
