240dreams »
https://forums.nicoclub.com/240dreams-u2835.html
Mon Feb 14, 2005 8:35 am
This is a copy and paste from my FA post:Alright heres the deal, spontaneously my car started to run like crap and idle very rougly. I checked for codes and I got a code 12 (MAF). I tried swapping out my MAF with another one of unknown condt but that didnt work. Same issue. I unplugged it and idle dropped about 200 rpms and it wouldnt rev past 2k or so. I tried cleaning both of them and everything but got nothing. I even tried to reset the code but it never went away. My car bogs and misfires pretty bad at all rpms - even idle. I know for sure it revs past 4.5k so I know the wiring cant be bad. Also, Ive been running the same wiring for about a year now. If someone can point me in the right direction to fixing this issue, I'd greatly appreciate it. Thanks in advance.
I forgot to add readings from my SAFC sensor check:Car off:In-1: .78vIn-2: .02v
Idle: In-1: 1.5In-2: .035
2.5k rpm:In-1: 1.99vIn-2: .045
Alright, I just swapped in my z32 MAF and I still have the problem only not as bad it seems. The Safc still reads an airflow percentage. My peak on the test drive was 40% at 6k rpm. The car seems to run fine under a light load like around 20% throttle. I traced my wiring back to the ECU grommet on the firewall and it seems fine. I didnt make any changes or alter the wiring at all so I dont think its a wiring issue. Again, Ive been running fine for about a year now and all of a sudden I get this - code 12. I tried resetting the ECU, disconnecting it, and unlpugging the battery. I still get a code 12. Any help would be appreciated.
Ok tonight, I recleared the ECU code and it went away. But, the problem didn't. Still bogs and misfires. I'm starting to believe that the problem may not even lie in the MAF. I changed the spark plugs to my old ones which worked fine when pulled. Problem still there. I listen to the injectors clicking and they all sound the same. I listened for the fuel pump and it still hums. After clearing the code 12, I got a code 55 (all is good). Can there still be other faults? What else should I look into that may be related to my problem? Thanks.
I just checked the coil packs according to the FSM instructions. All of them read .9-1.0 ohms. I also unplugged each of them during idle and they all made the engine shake when disconnected. Can the ignitor be bad?
