firstq »
https://forums.nicoclub.com/firstq-u958.html
Sat Jan 04, 2003 2:37 pm
Guys, I think I may a vacuum leak that only manifests when the car is cold. In the morning when I start the car, the brake pedal is heavy and the brake is sluggish - for quiet some time until the temp gauge comes to the middle. Once the car has warmed up enough, the brake pedal smooths out (light force results in excellent braking, what you would normally expect) and I experience much crisp braking (short stops - does not grag any longer).
If it were to be anything else than the vacuum, it would affect it both cold and hot, right?
Also, it really makes no difference if the car was warmed while parked or the car warmed up while driving on the road. Important to note that the symptoms does not change even after using the brake for some time - only when the overall engine temp rises to a certain level that the braking and brake pedal feel changes.
Any pointers?
Thanks
