spongey brake pedal 2001 pathfinder
toyotagearhead62
Car: 2007 Toyota FJ Cruiser , 2001 Nissan Pathfinder
does any know if these trucks have a spl. bleed procedure other then the normal right rear, left rear,right front then left front I have a spongey pedal after a rear brake replacement including wheel cyls. any help would be great Jonathan MeyerASE Master L-1
A2V
You should start bleeding on the farthest brake.
W O T
Car: 2001 Infiniti Qx4
Which he said he did......
What fluid did you refresh the system with?
Ive bled the brakes twice and the method you described using 2 people worked for me flawlessly both times
toyotagearhead62
UPDATE
I found the fix in alldata was the brakes do not get bled in the normal manner of rr,lr,rf,lf or starting the furthjerst away which is what we all think as the right way to do it the corredt way according to alldata and it worked for me was LR<RR<LF<RFthank you for your time in repling to me
