DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sat Aug 20, 2016 11:42 am
Assuming it's like my Powertrix one on my NA, there's a couple of nuts/bolts on the ends to remove and possibly another two out towards the tips that may need access under the two side hatch covers. Remove the center hatch panel to get to the side panels which clip in IIRC, you may need to pop off the hatch struts (a bit of a pita, support your hatch with a stick and a cloth wad as a pad, nearly fully up, and pop them off/replace carefully- the hatch is HEAVY) to get enough access for bolts. The 3rd brake light will be attached to the wing and have a harness to detach and it's off, reverse for installation...and lmk if this isn't so!
