01553-06511.... Clip, rear spoiler... $2.19 X 201553-39621.... Grommet............... $1.71 X 2silver2k2 wrote:I have a spoiler on the way to intall on my 94 Q......I need some clips that are a replacement item. I called EverythingInfiniti and they said they see no such part in FAST. Does anyone know the part number? Is there anything else I need. All the gaskets are in place
Jared plans ahead. He's already got the tan rear parcel deck without 3rd brake light. The plug for the spoiler brake light is under the trunk interior trim, waiting to be used. No extension needed.maxnix wrote:You will also need the T and a rear parcel shelf and maybe a harness extension for the CHMBL in the spoiler.
Well, I believe you can only hook up one brake light, and one of the best things about the spoiler is removing the interior CHMBL from the view and giving you a visual reference of the rear of the car when backing.db_autotek wrote:I'm fine with an extra brake light if thats all it is...really
If not, send it to me and I'll turn it into a Acrobat file.silver2k2 wrote:Wes did you ever publish my other one?
All model Q's have this already in the trunk waiting to be used and no extension is needed Brian.maxnix wrote:If not, send it to me and I'll turn it into a Acrobat file.
My main question is the extra harness tail standard in the trunk, or does it need to be purchased?
Which part is current and what about the stronger springs part number?94infinitiq45 wrote:If anyone needs a spoiler i've got one just let me know.Its from an A but is the same exact thing as the one for the T.You also need a rubber weather stripping like thing that runs around the edge of the spoiler,it seals the spoiler from letting water get under it.The one part has been discontinued but the other one is still available.
not sure what article you're talking about? Was it about the active conversion, because I think I might have, if not I will do that IMMEDIATELY.silver2k2 wrote:removing the extra light also reduces the weight thereby increasing 0-60 times
I will be sure to take pictures of the install to help others, maybe another article
NO way - just push the right side of the lense and it releases the spring clip comes out in 2 seconds.goody94q45 wrote:
Do remember to check the light before bolting down the spoiler. The spoiler lens doesn't pop out like the side markers. The only way I've found to change the bulb is to remove the entire spoiler from the trunk (PITA).
I recall it being both sides at once with the thumbs.jamesmost wrote: ...just push the right side of the lense and it releases the spring clip comes out in 2 seconds.
might be the only time i took min out was by accidentmaxnix wrote:I recall it being both sides at once with the thumbs.
Strange, mine pops out.No need for removal of the spoiler to get to it.goody94q45 wrote:Do remember to check the light before bolting down the spoiler. The spoiler lens doesn't pop out like the side markers. The only way I've found to change the bulb is to remove the entire spoiler from the trunk (PITA).
I fixed your link, it was taking you to the Q45 sub- forum, versus a single thread.
