silver2k2 »
https://forums.nicoclub.com/silver2k2-u57091.html
Mon Aug 20, 2007 9:05 am
As promised a How To
The unaltered trunk lid
Picture of the spoiler light plug, you can have both the standard CHMBL works in conjunction with the spoiler CHMBL. There is no extension needed for the wires
Mark the holes for the spoiler screws
Mark top bolt holes
Lay down plastic to catch all the metal shavings
Get out your drill and UniBit
Bold and nuts are around .20 inches, I drilled my holes 3/8 in as it allows a little play and the gaskets still cover them
You will need a Unit bit that goes up to 3/4. in for the spoiler wire plug
Holes drilled no going back now
Test fit
I had to swap my chrome emblems to the car as it had gold. I used tape to out line their location The emblems that go on the spoiler are curved, standard ones are not. However they still fit. I probably will replace them if I come a across a set
Attaching 3M Double sided tape, use a brand new blade
Done!
New toolbox emblem
