Spngr311's 1997 240SX
spngr311
Car: 1997 Nissan 240SX Daily and 1992 Nissan 240SX Project
Thought I'd start a new thread to track my car's progress. I just added a Version Select Body Kit, LED Tail Lights, and Tien S-tech's w/ KYB AGX's. This finishes the exterior for my 240 and I will now be moving on to the engine.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
Looks good!
Would look MUCH better with better offset rims and coilovers though!
none the less, i <3 koukis
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Yeah wheels are sunken like the Titanic but the rest of the car is clean. Engine?
Kckouki
Car: '97 Nissan 240SX
Looks good. But you need to do somthing with those wheels, those things are suunkin !
spngr311
I'm holding off on new wheels until I get a five lug setup and z-brakes. I may run spacers, but I'm not sure on what size to run. I used to run spacers on my truck and I had no problems.
I decided against getting coil overs because this is a daily driver that I will not track more than once a month so I cannot justify the harshness of them, especially for me and my bad back! I will be doing a KA-T on this one, started to get the components for that going.
S13xCrazy
^^all good enough reasons in my book. Well justified
spngr311
New pics:
redtop91
Bigtime fitment improvement! Front could use spacers but it looks great!
spngr311
I'm thinking about putting some 5mm on the front, or 10mm's with new studs - but it is definitely a start in the right direction.
ThuG LyFe
Car: 95 S14
yea much better than before dude. i was close to buying those 17x7 +42 offset fn's but i went with a much better size. so what else have u done to it?
redtop91
spngr311 wrote:I'm thinking about putting some 5mm on the front, or 10mm's with new studs - but it is definitely a start in the right direction.
Oh yeah definitely! You nailed the rear though IMO! (That's what she said)
adrianfromthecastle
Car: 1992 Nissan 240sx
big time improvement with those wheels.
IMHO, you should have went with the same sized wheel you did in the rears for the front.
10mm spacers aren't gonna do it dude.
I'd say go with some 20-25mm bolt on spacers. You don't have to deal with extended studs, and it'll fit better.
TheFallOfJeffrey
Car: 1990 240SX
I knew I saw this car somewhereI live in titusville.
VERY clean ride!
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
The S14 looks so much better sitting under palm trees! Nice car and great progress!
Thinking of the day when mine can sit under a palm tree again......Palm Trees, Tiki Bars, and Girls in Bikinis!
spngr311
It's already close to where I want them to fit at - the wheels are 18x9.5 in the rear and 18x8.5 in the front with +35mm offset on both. I'm running 265/35 in the rear and 235/40 up front. I think a 10 will bring it pretty close to flush - I'm not a fan of the JDM stretched tire sticking past the fenders look. But, you may be right, a 20 mm spacer may be needed. If I had gone with a 9.5 up front, it would hit the strut and and I'd have to run a 20+ spacer to clear it. The 8.5 just clears it.
Yeah, I'm up in the PSJ so you've probably seen my car around Brevard.
ilikebooze
Car: AE86
if those are the yashio factory tail.s then sexxxxxay!
