spluttering
midnightclubbaa
Car: Cars Clothes Music Girls
my car overheated and now it slutters.like it is only running on two cylinders. i checked to see which spark plug wires where working and 2&3 were not. what could be the problem?91 nissan 240sx with a 93 KA24DE motor
180fan
Car: 89 fastback
did you check your ignition wires? are they plugged into the distributor or have continuity through them?
hotshot240sx
Car: my 240sx
yes check for continuity, and also since you overheated i recommend you do a compression check just to be on the safe side. also check your coil.
NISTECH
when you do your compression check make sure all your plugs are removed. theres a good chance you warped the head or blew out the head gasket between 2 and 3.
