splitfire dis
OguraPowerTuning
Car: s13, b12, b13 ser
i dont know if this has been discussed before but is there a splitfire kit for the ca. or can you make the sr kit work? what is different about the sr coilpacks that would make them not fit?
NeedCAforS13
Car: CA swapped S13 coupe
RB kit uses the exact same coils, but you get 6 of them... Just order 2 kits, and split them with 3 CA guys! Have you ever looked at a CA coil pack next to an SR one? That'll answer your question of why SR ones don't work. Diferent lenght, different shape, different mounting points, etc...
Sean
float_6969
Sean's dead on. SR is a no-go, but the RB will work just fine.
OguraPowerTuning
NeedCAforS13 wrote:RB kit uses the exact same coils, but you get 6 of them... Just order 2 kits, and split them with 3 CA guys! Have you ever looked at a CA coil pack next to an SR one? That'll answer your question of why SR ones don't work. Diferent lenght, different shape, different mounting points, etc...
Sean
do you know where to buy the rb kit? i will buy it and keep the two extras.
float_6969
http://www.takakaira.com/
look around there.
niscort
how about a second hand set for the ca18?
Shoot me an email if your interested.
cheeRSglenn
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
do you need anything to control them? or just the coil packs them selves?
niscort wrote:how about a second hand set for the ca18?
cheeRSglenn
NeedCAforS13
pretty sure they're a factory replacement... damn if I only had the money! a set of second hand ones hasn't been on the market since I've been playing with CA's (at least not that I've seen )
Sean
float_6969
At what horsepower levels would they be nessicary?
ca18detizzle
^ good question, any answers?
onevia1800cc
Car: 1989 240sx ps13
i'm sure they would be good at any level of tuning. better spark=better response.oh i heard you have to rewire those????
8ggalant
Car: nissan cefiro
well they do LOOK like factory replacements...hmmm
niscort
They produce 150% standard amps, give around 8hp on a stock engine and are direct factory replacements, wiring wise im unsure.
company blurb"The Super Direct Ignition System is designed to provide a constant, stable voltage for high performance engines and will decrease ignition voltage loss at high RPM levels."
These are quite rare as mentioned.
Im asking 390us shipped
CA19DET
well i am running ~15psi on my CA with a T3/T04E and i need an ignition upgrade like this soon, i am having ignition problems in high RPM and heavy load... was thinking of getting the RB kit and maybe someone else can buy one and we'll ahve three happy CA campers...
i am also upgrading the stock ignitor to the AEM unit...
8ggalant
Car: nissan cefiro
CA19DET wrote:well i am running ~15psi on my CA with a T3/T04E and i need an ignition upgrade like this soon, i am having ignition problems in high RPM and heavy load... was thinking of getting the RB kit and maybe someone else can buy one and we'll ahve three happy CA campers...
do you know the price/where to order them???...im interested i just dont have any spare money to throw towards them @ the moment
ca18detizzle
we should do a group buy or something and divide the cost on the RB sets
Pumaking
http://cgi.ebay.com/ws/eBayISA...=WD1V
here ya go buy 2 and if 3 people go in its $380 plus shipping per group.
Turbogixxer
niscort wrote:They produce 150% standard amps, give around 8hp on a stock engine and are direct factory replacements, wiring wise im unsure.
company blurb"The Super Direct Ignition System is designed to provide a constant, stable voltage for high performance engines and will decrease ignition voltage loss at high RPM levels."These are quite rare as mentioned.
Are those the manufacturer's dynos?
niscort
They "apparently" produce.....
Turbogixxer wrote:Are those the manufacturer's dynos?
OguraPowerTuning
i will go in on a group buy. [email protected]
