Splashguard rivet? (below front bumper)
Karona
Car: '99 Infiniti QX4 (R.I.P)
'08 Nissan Rogue SL AWD
Hello, I was wondering if anyone had a direct answer to what kind of rivets I would need to reinstall my splashguard under the front bumper (below the radiator).
I've searched the forum and found 1 person state there is 2 sizes, one size is for 2 rivets that connect directly to the vehicle frame, and then about 6 other rivets to clip into plastic trims or something along this elimes, however no specific dimensions were mentioned and I was hoping someone could just say "oh you need at least two 10mm rivets, and five 8mm rivets"
I was having a fluid leak and most of my old rivets were rock hard and had to be snapped off at best.
Just wondering if anyone had that answer,
Thanks!
Rockhoundrob
Car: 2009 Nissan Rogue SL
check here.. this is for a 2009 Rogue
https://www.nissanpartsdeal.com/parts-l ... m=620_A002
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
I think it's an 8mm. They're fairly easy to pop out, relatively inexpensive and can be found at the big box hardware stores. Pop one out from the opposite side and take it to the hardware store. They're sold individually and you won't have to pay the shipping charge a parts supplier would charge.
RCH
Car: 2016 Nissan Rogue SV
I bought a pair (2 pieces) at AdvanceAuto. Here's the link : ----> https://shop.advanceautoparts.com/p/dor ... 11910906-p
It's a little bit pricey to me. So, If you need a lot of these, try Amazon.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Nissan are typically 8mm, they are $0.15 each from Rockauto.
I consider them a one time use unless you are removing them within one season, then they "might" be reusable.
I personally get them in variety of sizes from Ebay or Amazon for pennies.
Here is the link for the Dorman at Rockauto.
https://www.rockauto.com/en/parts/dorma ... tainer,690
Karona
Thanks everyone :)
Return to “Rogue Forum”
