Inner/outer tie rods
Rucas
Toe rod
Traction rods
Tension rods
And bigger sway bars
LET THE BATTLE BEGIN
this.Razi wrote:When I buy adjustable arms, I'll be buying from SPLparts.
Great quality parts, they use quality rod ends on their arms, and whenever they create a better version of their arms they let you upgrade for cheap.
So you think the energy suspension complete hyperflex kit would do the job. I mean its not like the car is going to be slammed. Because im going with kyb agx shocks with eibach springs,with 17's.numbnuts240 wrote:replace the bushings in your oem arms. if all you're going to be doing is cruising around with a rare autox session, getting adjustable arms is a complete waste of money.
I'm on lowering springs with agx's and I didn't need any rucas or anything. Alignment is a yes though.biggie wrote:May still need some things to adjust alignment, just depends on the drop. At least tension rods and possible RUCA.
Thanx i started to say pbm vs spl vs megan. but i believe im going to just order the hyperflex bushing kit, kyb and eiabach springs.simmode1 wrote:Great thread! I've been wondering abut this for a while. Subscribed.
