logoung wrote:The factory arms are only adjustable to a certain degree, in fact, i was informed that you can't necessarily adjust alignment with stock arms becuase they are static....
They are static - hence camber bolts (and condition of your bushings ) - also as I said earlier.
Camber bolts are standard practice, most of the ppl on this board who lower their car, whether it be via springs or coilovers, usually have had experience w/ camber bolts. Many of these guys also track their car. Eibach stuff costs more than ebay stuff for a reason, and it's not just name brand.
To the really important question to answer if this is overkill for you or not (which it probably is w/ the little info we have), have you already installed the eibach + prokit?
If you have, go get an alignment asap, unless you wanna spend a couple hundred dollars replacing your tires prematurely. Or at least get a free alignment check first, to see how much you are out of spec.
If you haven't, why not get ruca's or camber bolts or nothing? You are not lowering your car 4", or 2" for that matter.
And if you are really tight on a budget, why not go gr-2's w/ pro-kits? will save you a good 100 or so dollars and still handle better than busted old shocks.
RUCA's and even camber bolts when lowering on pro-kits is like using a condom during foreplay... "mostly" unnecessary given a few factors.
