Projex240 wrote:I talked to spl a while back and whoever I spoke to , I asked about the lca for the rear---what is the benefit of having those tubular or no tubalr lca on the car--do they have the benefit of keeping the front end more stable it full lock, etc--I am just now learning about drift and grip suspension. I have mostly been into drag and road course til now, but I have now the need to get the suspension tuned properly.ANy help is appreciated.
Honestly as far as adjustability of the suspension goes there isn't anything that you specifically need for drift or grip racing. They all are equally effective at improving suspension geometry which is equally important in any form of automotive racing.
The front lower control arm allows you to adjust the roll center (read: roll couple) of the car. This has a similar effect to raising spring rates and sway bars, however it does not impead the amount of compression (aka suspension travel) of the dampener and spring. It also replaces the factory rubber bushing with a heim joint to reduce compliance. Overall they are an effective upgrade and a must for someone looking to get 100% out of their suspension setup.
