raw0330 »
https://forums.nicoclub.com/raw0330-u9768.html
Thu May 14, 2009 12:09 pm
DEFINITELY freeze the bushings. heating makes them more succeptible to damage and warpage. Freezing them just makes them smaller to install easier. they should be pressed into place and not pounded, so as long as they are nicely perpendicular to the subframe and not frozen with liquid nitrogen (use a freezer!) being brittle won't matter. Oh, if possible, do it in hot weather so the subframe is as expanded as possible. DO NOT heat the subframe. This will weaken it.
