SPL Pro Aluminum Subframe Bushings - S13 Installation (beware 56k)
2Fass240us
Car: 93 240SX SE w/redtop
In case you're wondering, I have a similar thread here on FreshAlloy. I decided to post it here in response to another post about the bushings.
Using the SawzAll to remove the rubber subframe bushing:
The inner metal sleeve and some rubber, after removal:
Burning the bushings out:
"Uh huh huh, hey Beavis: Burnination is cool!"
The aftermath. Notice the brittle rubber pieces left over, and discoloration of the subframe:
The old subframe bushing outer sleeve:
The sandblasted 180SX subframe:
Frozen SPL aluminum bushings:
One bushing installed by heating the subframe with an oxy-acetylene torch:
Installing the bushings using a vice:
All 8 bushing pieces installed in the subframe:
The complete subframe after being sprayed with some Eastwood Epoxy spray paint:
My teammate Rob holding the subframe while I “mechanically persuade” it to go on:
The subframe being difficult about going back on:
The tools of mechanical persuasion:
Installed!
Chingon
Car: 1991 and 1992 hatchbacks
pretty cool.. let's see if the mods stick your picks over here: http://www.nicoclub.com/zerothread?id=97924
2Fass240us
Chingon wrote:pretty cool.. let's see if the mods stick your picks over here: http://www.nicoclub.com/zerothread?id=97924
Nice installation guide. I figured I'd post mine to give people a different set of experiences and pictures. BTW, your camera sucks at focusing!
A SawzAll is essential for this process IMO. Not only did it help to get most of th rubber out before I used the Oxy-Acetylene torch, but it also made quick work of the outer metal sleeves. I just had to be very careful not to damage the subframe collar itself.
I was also lucky because I was able to sandblast and paint mine before reinstalling it. This is mainly because my car isn't daily-driven and I could stand the downtime.
Chingon
..hehe. The camera doesn't suck at focusing. I do! I had it @ panoramic view or something...instead of close-up. You can see that the far things look nice, while the close things (important) are out of focus.
2Fass240us
Chingon wrote:..hehe. The camera doesn't suck at focusing. I do!
I was trying to be nice...
