SPL Coils, T/C rods, & RUCA Install!!
Anand
Car: 95 Nissan 240SX
Finally…(WARNING: THIS IS A LONG WRITE-UP!)
This is how you install SPL Coilovers, SPL Tension Rods, and CUSCO RUCA’s
Tools you will need:
WD-40 or something similarTorque wrench (0 lbs ~ 150 lbs)Various sockets, ratchets, breaker bars (the ones I can remember are 10mm, 14mm, 17mm)About 4 hours of timeAnd one other friend (don’t really need but it’s better to do work with friends)
We decided to install the front coils first…then the tension rods
I sprayed all the bolts and nuts that were going to be taken off with WD-40 liberally and let it sit for about 5 minutes.
Then we went at the darn bolts with a breaker bar.Be careful when trying to take these 2 bolts off:the reason being, once the bolts are off… the whole assembly will fall down.. so don’t have your knee or anything in the way!!
Then you take the top bolts off (no pictures of that because you don’t need them)
Once you have the stock strut bolted out and out of the way, you pick up your coilover and figure out and eye ball the height you want..(this will be fun later)
Slide the 3 bolts through the top and bolt those down per specs:
If you want the FULL size picture of that click here:http://nissaninfiniticlub.net/...3.JPG
then you bolt the lower part to the brake assembly. What I did was I put a block of wood under the assembly and then used my jack to jack it up while I aligned the holes.
Bolted those 2 bolts to specs:
FULL size pic:http://nissaninfiniticlub.net/...5.JPG
Since the SPL coils do not come with the brake line holder thingy, I had to zip tie it to the strut like this:
Installing the Tension rods was really easy
You just unbolt the 2 bolts from the underside of the lower control arm and the big bolt in the front.
Then in reverse order bolt it back up. *refer to the chart above for torque specs
One note about the SPL Tension rods..the bolts that they provide with the T/C rods are made for a 18mm size Allen key!! <~ Which is NOT supplied
I had to make a quick run to Home Depot to get one and I HAD to buy a big set with one in it since they didn’t have a separate 18mm key…L
BUT! When we bolted the sucker up… we didn’t even need the Allen key to hold the bolt in place or anything….
I don’t know if everyone has the same experience or not but I didn’t like going out at that time to get a 18mm size key.. I mean, unless you have a shop, you are never going to need that size Allen key.. so just be warned…J
Finished product:
Now comes the rear Coilovers
Use the same technique on unbolting the rears as you did in the front.Watch out for the rear assembly as well.
Remove the old stuff out of the way and bolt up the top 2 bolts of the strut assembly.
Use this cart to help you bolt it back up to specs:
FULL size:http://nissaninfiniticlub.net/...4.JPGh ... t/...6.JPG
This is very simple procedure. The only hard part is to eye ball the height of the coils. That you will have to play around later.
For the inside top bolts, I had a rubber boot, people told me that they just threw it away. I said hell no! I am going to keep it and still use it so I cut a hole in it for the knob to pop through and it worked!!!
DO NOT FORGET TO TIGHTEN ALL THE COLLERS ON YOUR COILOVERS BEFORE YOU DRIVE OUT!!!!!
Now comes the RUCA’s
There are 2 bolts that you have to worry about. The front bolt and the rear bolt.The front bolt is simple and easy. (CUSCO provides a shiny new one with theirs)The back one is the ESSENTRIC bolt.note * be very very careful with this…make sure you know how it come out so you can put it back in the exact same way!
To adjust the RUCA, again, eye ball it and make it the same length as your stocker:
then bolt that sucker up with the specs that are provided previously:
Finished product:
You can always e-mail me for help if you need to!!!
Enjoy!
*Special thanks to Brian (PGBrian) and Norm (S14SRPilot) for helping me out!!
Anand
ANOTHER NOTE
GO GET AN ALIGNMENT ASAP!!!
SeVa-S13
Car: '05 GTO 6spd
We have the same breaker bar. <3
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
nice man!
i2ice4m3
Car: COUNTERSTRIKE!
did the alignment guys adjust the rucas and tc rods for you too? looks really nice btw
w1ngzer0
Car: Pfft. i don't own a box
hey can you take a picture of your tire next to your shock/spring assy. I have a problem where my tire hits my suspention in the front. I don't know if it actually "hits" but its really weird how it looks.
Just take a picture close up of your tire and suspention together.
gabossie
Car: Your mom
Awesome. I can't wait till mine get here. You should have hit me up Anand, I could have hooked you up with the alignment.
Anand
haha.. I haven't gotten the alignment as of yet..
no time.. I want to get it done this weekend.
let me know where I can take it. call me up 714-325-2841
