Dookie »
https://forums.nicoclub.com/dookie-u11327.html
Thu Dec 09, 2004 6:00 pm
Well, I put in my SPL line I got yesterday, the line itself looks great Shame itll be coated in road grime in a week or so. I ran into a bunch of problems installing it though. I wasnt sure if it bypassed the damper box or not, so I just assumed it did. Boy I was wrong. I ended up bending the clutch line until it could reach the stainless line. I also rounded the nut on the fitting of the clutch line, so I had to use vise grips to loosen and tighten it. My friend and I started to bleed it, but after numerous attempts at bleeding, we found out the slave cylinder busted Had to go to autozone and get a new one. Got one and found out the threading of one of my bolt holes to the slave cylinder is stripped out THEN on top of that, I forgot to put the rod inside the new slave cylinder, so the cylinder just popped out. Went back to autozone and they had another one, thank god. Put the rod in and put the cylinder back on. Bleeding screws up again, I yell the F-word and my neighbors hear me. I look under and I forgot to tighten the line, stupid me.Bleeding took about 10 seconds. So easy, in a way, heh. The clutch sorta feels better, not to what I thought it would be though.
Sorry for the long post, I had a long day. Nismo_Freak, you guys make some good looking lines.
