SPL Adjustable Upper Links
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
The old style vastly superior Z32 SPL Upper Links are available again from SPL Parts. Saw about 4 sets there. These will work spendidly on a G50.
Call them for information.
http://www.splparts.com
qship96
Car: 1996 Infiniti Q45
Cost???? Any advantage to these over factory parts on my old Q that camber still measures in spec?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Allows adjustment of camber, will last a long time. May not be as quiet.
Probably around $300, but I don't know.
More important for those with lowering springs.
Trumpkin
Car: 1995 G50
Didn't james bust a set?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I don't think so. I believe those were the Stealin' ones.
NOR*CAL 916
Car: 1994 infiniti q45
i have the STILLEN upper links and they gave up on me about one year into them the polyurethane bushing cant handle the weight of the Q45.
Rex
Car: None
Yes, Jamesmost busted a Stillen unit.
NOR*CAL 916 wrote:i have the STILLEN upper links and they gave up on me about one year into them the polyurethane bushing cant handle the weight of the Q45.
Unless MoD has made some changes, Da Beast has a set on the front that have been on the car for close to 4 years. I think a key to the longevity of these is regularly greasing them.
NOR*CAL 916
Oh yes i greased the crap out of them hahaha, mine did not totally fail on me the bushings just off centered the bore the bolt goes through, in my opinion the SPL units look to be better quality, i need to buy me a set.
BLACKonBLACK98
Car: Q45, LS400, STS-V
so is the entire multi-link setup from spl g50 compatible? i was planning on importing some jdm g50 specific parts but everything looks very similar and the savings would make it worth it. the added bonus of driving a couple hours to have them set it up is a huge bonus as well.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Rex wrote:Unless MoD has made some changes, Da Beast has a set on the front that have been on the car for close to 4 years. I think a key to the longevity of these is regularly greasing them.
Yeah, they're still on there. They definitely require regular greasing. Good to know people have broken them in the past...now I'll be extra-careful about greasing them.
NOR*CAL 916
BLACKonBLACK98 wrote:so is the entire multi-link setup from spl g50 compatible? i was planning on importing some jdm g50 specific parts but everything looks very similar and the savings would make it worth it. the added bonus of driving a couple hours to have them set it up is a huge bonus as well.
On my car the front tension rods are by TEIN and are S13 chasis 240sx parts, direct bolt on. The rear upper control arms (RUCA) are Stillen parts off of a 240sx, the front upper control arms (FUCA) are from a 300zx and the Toe rods are from a 240SX from SPL. All are bolt on and work great except the front uppers i have had problems with those as far as quality.
BLACKonBLACK98
how about lca's? i have noticed a lot of these parts are listed across the s13, s14, and z32 chassis by some manufacturers so i can pretty much figure out interchangeability for the rods and uca's but lca's seem to be much less common, due to cost no doubt.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
remember that if you want to install these upper links on your car you MUST have a set of solid tension rods on your car!!!!!!
qsiguy
Car: 1994 Infiniti Q45 Turbo
Wes, can you please elaborate on that comment? Do you mean you should have non adjustable OEM ones or aftermarket adjustables with the "solid" non rubber ball joints on the ends?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
How harsh would the ride be with the SPL special (putting everything that SPL offer on)?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Think he means the solid bearing adjustable ones.
elwesso
2007 BMW M Coupe
The issue is there cannot be any play in the caster direction with the solid upper links. The reason is a bushing allows some movement in the fore/aft direction, but if you have some caster play you will wear the bearings out prematurely...
Even having poly bushings in the stock tension rods wouldnt be enough I dont think. I believe SPL requires that you have the solid bearing adjustable tension rods in order to honor any warranty claims.
the nice part about all the solid stuff is that while its slightly more harsh (but its worth it IMO for better handling) is you never have to replace those components again, you just replace the bearings when they wear out!
NOR*CAL 916
Paul Wall wrote:How harsh would the ride be with the SPL special (putting everything that SPL offer on)?
You will notice and feel the road more throught vibration in the steering whell its slightly more harsh but its still comparable to a stock Q just sportier. I love them because you can accurately adjust the links back to oem specs when you lower the car.
elwesso
2007 BMW M Coupe
agreed, and the feeling in the steering wheel is amazing, feels like its on rails!
Trumpkin
Car: 1995 G50
So what your saying is you can't get oe specs after you install lower springs?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Trumpkin wrote:So what your saying is you can't get oe specs after you install lower springs?
Not without shimming the upper llink inboard mounting bracket.
Flagship-Q
Car: 1992 Infiniti Q45
Dang! I hope i didn't screw up my suspension rehab project and alignment. I just had O.E. tension rod bushings pressed in and have California Custom springs to install as soon as i buy Tokico Blues. I'll also have active swaybars to put in. Hopfully everything can be aligned up right!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The rear requires a Z32 RUCA to align correctly, after you shim the front upper link brackets.
elwesso
2007 BMW M Coupe
the camber is going to be off but not enough to matter IMO. More important to get an alignment to get the toe back in spec.
