Postby
rico05 »
https://forums.nicoclub.com/rico05-u8176.htmlTue Feb 01, 2005 6:45 am
I see that that they are finally done. I would like a little more preload in my sway bars (could be a little snappier in weight transition) And for the money, I think I like my sway bar setup (24mm USDM SE front bar, 21mm K's rear bar) but I am wondering if I will actually notice any qualifiable difference. Thanks man! I want to buy something other than fittings from SPL!
Postby
Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.htmlWed Feb 02, 2005 3:49 pm
I'd say you can typically chalk up a fair amount of bar rate into endlink play (10-20% depending on condition). Since you have relatively thin bars (compared to some aftermarkets), I think the endlinks would benefit you.
Postby
turtl631 »
https://forums.nicoclub.com/turtl631-u15171.htmlWed Feb 02, 2005 7:37 pm
Alan, do you think its worth it to get these for the Whitelines? I'm thinking that since they come with poly bushings, solid links are going to have dimishing returns.
Postby
Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.htmlThu Feb 03, 2005 3:21 am
turtl631 wrote:Alan, do you think its worth it to get these for the Whitelines? I'm thinking that since they come with poly bushings, solid links are going to have dimishing returns.
They allow bar pre-load.
If you don't think you are going to use that feature and/or are willing to live with what you have then I suggest against them in your case.
