spit and sputters
chase
I need help! i have a 95 240. it is started to miss and miss hard mostly under load, it almost feel like water in the tank but the fuel is fine. this is what i have changed, spark plugs, wires, coil-distributor, fuel filter, cap and rotor. something is odd everytime i take my car for a test ride 1 and 3 cylinder spark plug wire boots are up 2inches.:confused: :confused: :confused: :help
PapaSmurf2k3
Site Admin
push them down hard, if that doesnt work, buy new plugs and wires, and make sure that they stay down.
groundhogday1976
Car: 2015 Altima 2.5 S
Something to check on the wires that are coming up: shine a flashlight down in the plug holes. If you can't see the hex nut part of the spark plugs, the rubber from your old wires is stuck on there. It's a pretty common problem. It happened to me and I used a fillet knife to pry the rubber pieces up.
chase
thanks but i already checked that.
chase
i think i fixed it. i added 2 extra ground straps, it has not messed up all DAY:) :cool:
chase
