trpower7 wrote:With a VLSD both tires should spin no matter what.
This is not true, that would only occur if it was a welded diff or 2-way diff. An open puck differential sends power to the wheel with the least resistance. An LSD sends power to the wheel with the most resistance.
When sitting on regular pavement, both tires have the same resistance so they get the same amount of power, hence the two-wheel burnout.
However, when putting one wheel in a puddle, and the other's on pavement, the pavement wheel will take precidence and get the most horse power, causeing the car to have uneven traction. And an open-puck differential would spin one tire, because its not resisting, taking presidence with the tire in the puddle.
On a side note, the r200v VLSD is not a 2 way LSD, so at times it will revert to an open puck differential...(under braking, non-accelleration, deceleration, not enough brake-away torque - 50lbs)...
My guess is, your vLSD was running as an open-puck diff because there was not enough break away torque, and then heated up forcing the vLSD to briefly engage, and the tire on the pavement caught and made the car slide out....
