Spinning Lug Nuts...help?!
KageBushin
Car: 95 240SX (POS14)
my lug nuts are spinnin, i replaced them about a year ago, and when i went to rotate my tires, 3/4 lugs are spinning..any bright ideas on how to get em out? ive searched and found nothing =/
fourLUG_hero
If you don't really care about the face of your wheel, break the lug nut with an air chisel.
Car: 240sx
do u mean the threads on the stud are stripped???
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
yeah are the studs spinning or the lugs stripped onto the studs?
KageBushin
the studs are spinning, and they're enkeis, so theres no way to get a chisel in there =/
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Rough place to be, drill the stud out from the back, or weld them to the hub. Then replace the hubs
adrianfromthecastle
Car: 1992 Nissan 240sx
yeah, both that stud and the hub are most likely effed.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
KageBushin wrote:my lug nuts are spinnin, i replaced them about a year ago, and when i went to rotate my tires, 3/4 lugs are spinning..any bright ideas on how to get em out? ive searched and found nothing =/
That's happened to me a couple of times. Are you able to turn the lug nut? Trying to loosen it up but it just doesn't seem to get loose? Then the stud if done for. Just keep turning it until the stud snaps. Unless it's just free spinning. then...
adrians_s13 wrote:yeah, both that stud and the hub are most likely effed.
KageBushin
well it took 4 hours of trial and error, but i finally was able to drill those buggers out with a hammer drill and a titanium bit.
All I had to buy was the bit, some cutting oil, and the lugs/studs
w00t
