spindle nut?
nd_aussie
Car: 1994 300zx 2+2 bout to be tt&1987 rx7 s5 turbo II
ok so i changed my wheel bearing in the rear and i heard yesterday not to tighten the spindle nut down all the way but a guy at the shop told me to just put the impact wrench on it and then itll be fine. ive been noticing alot of noise in my rear end like grinding of a bearing. which makes me really mad cuz i was dumb and listen to retards if i ruined this bearing. on top of that i think my rear diff took a crap cuz i cant even turn and gas it and have the wheels spin it feel like no accel during a stop and right turn.
ArticDragon192
Car: 91 Z32 2+2
You mean the axle nut? Yeah, I usually just gun it on. Then replace the cover and the cotter pin in place. It does have a torque value to which it is set at though.
nd_aussie
yea then its the effn duralast pos. what about my lsd?
nd_aussie
anyone?
CrazedZ32Owner
Car: 91 Z32 TT(no motor), 2008 350Z Nismo, 05 Pontiac Sunfire speed machine!!! :)
i would like to know as well b/c i have to replace a wheel bearing this weekend
robomatic12
Car: 1990 300ZX TT
There is a spec in the 300zx service manual, but the norm is to gun the nut down till it stops then you can insert the cotter pin thru the little castle nut cover.
nd_aussie
so tighten it with the gun, no loosen?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
If you're really that concerned, look up the torque spec in the FSM.
http://www.nicoclub.com/FSM/300zx/
nd_aussie
im only worried cuz my back end is making a grinding noise only some times.like a bearing blew. and im scared about my rear diff i really cant afford to have it go out on me. but im bout to jack up the car and take the plug out of the rear diff and see if theres any shavings
CrazedZ32Owner
that would be your best bet.... let us know what the deal is
nd_aussie
what is your best opinion?
robomatic12
Car: 1990 300ZX TT
You replaced the bearing yourself? Did you have somone press it on for you? What brand of parts did you use?
There are like 100 things that could have gone wrong during this repair if you are not qualified.
nd_aussie
i had a shop press it in. the bearing was duralast(yes i know pos thank you haha)
es.biggs
Car: 1990 300ZX 5sp NA
Tighten the mess out of it. FSM recommends 150-200 ft/lb of torque which is tighter than wheel lugnuts on full size pickups.
Most of the time when a bearing is bad you can hear which side it is...when you drive it if you shift the weight of the car from side to side and the noise gets louder and quieter with the weight then it's probably a bearing problem again. Lift the back up and check for play in the wheels, spin the wheels around and make sure it's smooth, no grinds.
That's my normal routine for checking wheel bearings.
CrazedZ32Owner
another way to do it is take off the wheel,caliper and rotor. Then take the ABS sensor out of the hub and listen in that hole while you turn the wheel. If you hear anything like grinding or clicking its your bearing.
