twisted99s10 »
https://forums.nicoclub.com/twisted99s10-u66955.html
Wed Aug 12, 2009 7:43 am
hey guys, im having a bit of an issue. i have an s1 rb25, with walbro 255 fuel pump, q45 maf, fmic, 3" exhaust. "tuning" it with a safc II and a wideband. every once in a while it would "blip" lean for just a split sec then run fine. lately when im driving it will spike lean for several seconds, even sometimes completely stall out. its acting as tho it isnt receiving fuel. the fuel pump is continually running while this happens. all of the wiring still checks out (no bad connections). iv replaced the fuel filter, replaced the vacuum line to the fpr. checked and rechecked everything, im completely lost. any one have any ideas?
a little bit of other info, at idle it often gets stuck running either way rich (12-13:1 afr) or way lean (16-18:1 afr).
thanks in advance.
