MisfitBrian »
https://forums.nicoclub.com/misfitbrian-u72658.html
Thu Apr 24, 2008 9:20 am
And before it gets asked....Follow these steps:
1 Wash and dry your vehicle.
2 Spray a small area with clay lubricant(quick detailer spray), no bigger than 2 square feet.
3 Gently rub the clay bar back and forth across the wet area. It will grab at first. This means that it is pulling contaminants out of the paint. When it glides freely, the paint is clean. 4. Wipe the area with a microfiber towel and use the clay lubricant to remove any clay residue. Rub your fingers across the paint now; it should be as smooth as glass. If it’s not, repeat the process. Reshape the clay bar as needed to expose a clean surface. Keep the clay well-lubricated. 5 Continue these steps until you’ve clayed the entire vehicle. Clay does a marvelous job on glass and chrome, too. 6 Store the clay bar in its original case if possible, or in an airtight plastic bag. Spray it with lubricant to keep it moist. Do not allow the clay to freeze and do not store it in temperatures above 200° F. 7 Always follow claying with a wax or sealant. Clay will removing existing wax and may leave tiny holes where contaminants have been removed. They must be sealed in order to protect the paint from corrosion.
