centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Thu Feb 09, 2017 2:00 pm
It is my understanding that most of the comfort comes from the suspension (springs and dampers) not the joints. Like, stock suspension with all joints being ball would be pretty similar in comfort to OEM. The typical is all ball joints and stiff track suspension, so it's not comfortable, but the primary source of discomfort is the higher spring rate and slower damper. Why are you planning to spend on adjustable arms? You could have OEM with rubber, urethane, or pillowball joints. You could get eccentric bolts if your can't achieve proper alignment with the OEM adjustments. I suppose you're planning on going really low? That will reduce your arm travel, so you get higher spring rates to keep the arm located in a smaller triangle, so you get a damper that handles that without blowing, so you end up with a rougher ride and it's so low that OEM adjustment wont work and you compensate by getting these adjustable arms to correct the geometry. At least I think that's the ripple effect of lowering. Finding someone with ball joints and OEM or 'soft' suspension might be tough.
