speeds in each gear
wangless
Car: '02 MBP WRX
first off...
i was messing with my speedometer, i took off the needle... then i put it back on... then i put everything else together then drove off... after i did that... my speedometer wouldnt go lower then 20mph... it was even like that when i turned off the car... do i had to take out the whole gauge cluster again... drive and try to adjust it properly... but im still not sure how fast im going... so can anyone tell me how fast they are in each gear with the rpm ?... like 1st gear @ 3k would be... blah blah... i wouldnt know bc i dont know if my speedometer is properly working... oh yeah... when i slow down quickly... the speedo lags... is that normal ?
btw.. i have a '90... and thanks !
NeverEnuff
Car: Cars and Girls
well i have a 92 but i can tell you how fast it is in gears 1st @3000rpm is 17 mph 2nd @3000 is 33 mph 3rd @3000 is 45 4th @3000 is 56 5th @3000 rpm is 76 i dont know but i would say all cars are probly dif thow but it might be close althow im not shur but i think your car has ka24e mine is de not shur what dif this will make but owell hopfuly this might help you
wangless
Car: '02 MBP WRX
thanks, anyone with a sohc ?
